Arias piston rings
Old Jul 30, 2007 | 08:54 PM
vtec dub's Avatar
Default Arias piston rings
Hi Guys. I am starting my assembly with my b20 sub-assembly. I am having a problem identifying which way should my rings face.
the one has a yellow mark on it and the other one has a red and a yellow mark on it. and both of them has a very small dot on the one-side of the ring.
What i want too know is which one is my top compression ring and which one is my second compression ring and which side is top and which side is bottom?
thanks for the info in advance.
Old Aug 2, 2007 | 11:53 AM
Lubo_25's Avatar
Default Re: Arias piston rings (vtec dub)
if there anything like my cp rings a dot or lettering face upwards and if theres neither anyside up...but you should read your spec sheet they all come with them...or did you lose the sheet?
Old Aug 3, 2007 | 03:37 PM
PHDZINE's Avatar
The dot faces up and the thinner ring goes on top or compress the ring together with your fingers (close the gap) and the one that is harder to close is the upper ring.
Old Aug 3, 2007 | 03:39 PM
PHDZINE's Avatar
Default Re: Arias piston rings (PHDZINE)
Another way to tell the difference is...the lower ring will have a groove on the bottom when the dot is facing up.
ZCHondaCRX91
Engine Machining & Assembly
Sep 14, 2015 04:23 PM
PARADOX_sf
Jan 3, 2011 05:42 PM
EJ8chu
Jun 16, 2008 05:26 PM
2 0 3
May 6, 2006 04:23 PM
ericrx_88
Jun 1, 2005 11:34 PM
