Anyone Ever Heard Of This?
Old Oct 20, 2013 | 11:59 AM
th3pwn3r's Avatar
Default Anyone Ever Heard Of This?
So on Friday I was driving my car calmly and I shifted from 2nd to 5th and stalled it out. I went to start it up and the engine(B18C) was just turning over, I noticed I wasn't hearing the fuel pump anymore, I'm not even certain the ECU is working either. I checked all fuses and everything looked fine, I checked out wiring and that all seemed okay(nothing broken that I could tell). The relay that goes to the pump(a Bosch 044 under the hood) had power at 4 of the 5 posts and was clicking so I believe that's fine, I should have jumped some power to see if that would do anything and should have connected my laptop to the ECU(I have Hondata in my CRX) and see if it was detecting it. I'm just baffled that something could short out from just stalling it out really. Perhaps I shook something hard when it stalled and that is causing a short or grounded out wire...
Old Oct 20, 2013 | 07:10 PM
motoxxxman's Avatar
Default Re: Anyone Ever Heard Of This?
clean and tighten all ground wires. it probably vibrated an already dirty and loose ground
Old Oct 21, 2013 | 07:01 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car, Honda/Acura fuel pump relays, [PGM-FI Main Relay] is under the dash.
The PGM-FI Main Relays are a common problem on older Honda/Acura and are repairable with a little re-soldering most of the time, search main relay repair. 94
Old Nov 3, 2013 | 02:59 PM
th3pwn3r's Avatar
Thanks for the responses. I finally got around to looking at it again and all wiring appears to be good. I jumped power to the pump and it was running so I don't think anything is shorted. I'm guessing it's the main relay causing the problem here. I'll try to get to it this Saturday and report back.
Jamesb223
Jan 21, 2018 08:01 PM
redline1320
Apr 27, 2010 06:55 PM
86crxintheworks
Jul 13, 2006 06:48 PM
95turboeg
Jul 7, 2006 11:38 AM
