Okay heres the story cut short. Drove the car parked it made it cool down. The dizzy worked fine its just that it was leaking oil, so i took it out took out the rotor and tranfered it over to the other dizzy then tried starting it up . . and it wouldnt. The car cranks and all theres fuel ( I have two FPR gauge) and i can the car has backfirce i dont know why but it does. So i said oh maybe mad dizzy so i took out the rotor again put it abck to the dizzy i was running then still didnt start. Could it be because i touched the rotor oil on my fingers when tyring to take it out. Need help please. .. cna oil burn out a rotor that fast i dont have a spare rotor.
firing is right checked it 3 times
Maybe your spark plugs got fouled during the whole mess? I would start there.
so you checked it 3 times... are you sure you got the right order?? you said the car has backfirce? what does that mean?
my car had back fire specialy when i ran cold plugs for nitrous. Figured it out already . . . the rotor i guess burned out. Cuz changing that out car started up and ran fine. Yes the firing order was 4 3 2 1 cylinder starting from the dizzy side and 1 3 4 2 starting from bottm left going clockwise on the dizzy so im pretty sure i had that correct. Got it done thanks all for the help.
