Alternator for 1st Gen B16
Which Alternator should I use the factory on it not charging OBD-0 ?
Are there any fuses in the charging system? Remove jump box after the car is started and the volage decreases and engine dies since there is not enough voltage.
JAson
JAson
Sounds to me like the battery may not be holding a charge. Make sure that it does. If it does then replace your alt. Thats the problem most of the time. If thats not it, it could be the voltage regulator.
Blaze
Blaze
The battery only starts the car. THe alternator run the car after its started. You can actually remove the positive battery terminal when the engine is running to test the alternator. Unhook jump box the voltage goes from 12-10-8 then dies from not enought voltage to run car. I'm 95% sure its the alternator.
hondaracin24
May 30, 2005 08:17 PM
