All Motor Pros I Need Input
Old Jan 26, 2003 | 11:21 PM
crazyitr's Avatar
Default All Motor Pros I Need Input
Ok, Here is the lowdown. I have a Golden Eagle Sleeved b16 that's bored to 84.5 mm. I am going to run Eagle Rods and Wiseco Rollerwave Pistons (Endyn) that will yield approx 12.5 : 1 compression with my p28 head. I have a stock b16 crank and stock b16 length rods. My head is at Alainiz's shop. He will be blueprinting the head, cc' ing the chambers, doing a full port and polish. Basically the works. After explaining that I am running Jun3 cams, Jun 3 springs, and Skunk 2 retainer, Alainiz decided to install oversized intake and exhaust valves (nitride coated and hardened stems: He is port matching and deburring my Victor X manifold and matching it up to a 70mm BBK throttle body. I will be installing a 150 hp direct port nitrous kit as well. I will run either Hondata or Speed Pro engine management. Here is the tricky part: What kind of header, cat and exhaust should I run. This motor is going into a EG hatch. Also what kind of clutch, pressure plate, and flywheel should i run. Since I will spin the motor to around 10,000 rpm, many people have suggested an unsprung clutch. High rpm shifting and nitrous are part of the mix. I have spoken to John at Hytech. Six to Eight weeks and $1200 don't make sense to me. SMSP doesn't return phone calls, despite two messages that I have left and no one answers the phone there either. I could build a custom 2 1/2" or 3" exhaust with a hi-flow cat also. Should I start with a JDM style, or an off the shelf Spoon or Toda header. John at HYTech tells me each header is custom, but he has 20 or so designs, I don't know if I can get my money's worth since he doesn't care to even ask questions about my setup, but mentions that he needs $500 up front to begin work. Having owned a SC'd type R, I have seen 20 hp at the wheels by switching out a mugen header to a Kamikaze header and Carsound cat. I went from 182 whp to 201-202whp with no other changes. I want experienced racers to input, all you paper drag racers with butt dynos need not reply. I will be happy to post dyno numbers and details of my upcoming experience.
Old Jan 26, 2003 | 11:56 PM
HookUpsImportTek's Avatar
Default Re: All Motor Pros I Need Input (crazyitr)
You ask for the opinion of all motor people and then tell us in your post that you want to run 150 shot of n2o. Let me give you atleast this advice. Your header and exhaust is the least of your worries. Your plans for the 150 shot are. Stay away from that because at that compression I am telling you, your motor will blow on the first run. As for your header question, JDM Type R header w/5Zigen Border or Miracle 2.5" should suit you fine.
[Modified by HookUpsImportTek, 12:57 AM 1/27/2003]
Old Jan 27, 2003 | 06:57 AM
gtpilot's Avatar
http://www.burnsstainless.com/index.htm - they have built me some wonderful headers...
Kirk
Old Jan 27, 2003 | 09:05 AM
CHEETAH's Avatar
before I answer your question, I want to make it clear that I'm very much "pro-HyTech" ...
anyway, you spend all that money for such a VERY NICE setup, only to cheap out on the heart of the entire system, the exhaust ... thats a nono, go with a custom header from someone who knows what he is doing. My all motor race car uses a custom HyTech exhaust, like everyone else a custom header more built for your long R/S ratio motor will make sense. $1300 is very cheap for what you are getting, take my word for it, I've spent about $40K on my racecar. And I have used every production header you can think about, in my past experience.
Greg
Old Jan 27, 2003 | 08:50 PM
HelloMeVerygoodFriend's Avatar
Default Re: All Motor Pros I Need Input (CHEETAH)
CHEETAH how much do u charge for a tarnny rebuild?? I need new synchros... sorry for thread jacking but 12.5 comp. and 150shot??? header ?cat?exhaust?? do some more research buddy
Old Jan 27, 2003 | 11:19 PM
B20Monster's Avatar
[ I have a Golden Eagle Sleeved b16 that's bored to 84.5 mm. I am going to run Eagle Rods and Wiseco Rollerwave Pistons (Endyn) that will yield approx 12.5 : 1 compression with my p28 head. ]
just wondering..isnt a p28 a sohc?
Old Jan 27, 2003 | 11:27 PM
crazyitr's Avatar
Default Re: All Motor Pros I Need Input (efzero)
I am still going to run a/c, in houston, texas it is way too hot not to have a/c on a street car. As for running nos, I have forged pistons, rods, and a sleeved block. If that's not strong enough to spray 150 on, I don't know what is. AN-R header that Erick's uses won't work, I don't know about the other style. Does anybody have any experience here.
Old Jan 27, 2003 | 11:30 PM
crazyitr's Avatar
it was late. I meant p72 (USDM GS-R Head)
thanks
Old Jan 28, 2003 | 02:42 AM
Unsung's Avatar
Do you even know what your talking about? Everyone has just told you straight-up, your basically on the totally wrong track. Do some research, ask specific questions, and use the SEARCH FUNCTION. It's amazing!
Old Jan 28, 2003 | 11:47 AM
10K2HVN's Avatar
Default Re: All Motor Pros I Need Input (JDM B-Series)
ah ha..! owned!! whats even more funny is that hes running a GSR head with 12.5:1's...so that makes is around 12.7:1 AND the NOS...lol!! you funny guy you...
Old Jan 28, 2003 | 12:22 PM
redsin's Avatar
from what i understand nitrous loves high compresion. as long as its tuned and the block will handle the hp numbers theres no problem
Old Jan 28, 2003 | 12:36 PM
evolve's Avatar
Default Re: All Motor Pros I Need Input (redsin)
That's a good one. Technically, all power adders love high compression, just the engine doesn't. The engine produces power via fuel combustion. All nitrous does is oxidate, it doesn't detonate the fuel. The spark still does that job(if built properly). The higher compression will yield the power production.
Old Jan 28, 2003 | 01:13 PM
evolve's Avatar
yeah, "Got detonation!?"
Old Jan 28, 2003 | 02:41 PM
GOLDBERG's Avatar
so would a 75 shot of nos be safe for a daily driven 12.5 compression motor???i'm going with either 12.5 or round 12.1 compression on a h22a or 2.0liter gsr motor and wanted too run a 75-100 shot..what would be safe
Old Jan 28, 2003 | 03:07 PM
10K2HVN's Avatar
Default Re: All Motor Pros I Need Input (GOLDBERG)
anywhere above 12:1 i dont think you should even think about NO^2...all a sudden, i dont think my planned 11.5:1 is high anymore.... maybe i should consider higher...?? i thought 10.5 would be perfect for nos...
...endyn forged piston would be the equavalent to the JG pistons right? forged alluminum wise...?
[Modified by 10K2HVN, 4:12 PM 1/28/2003]
sheepey
12
Mar 10, 2005 08:36 PM
K-Drum
Feb 21, 2005 10:45 AM
.derf.
Oct 15, 2003 07:50 AM
crazyitr
May 16, 2003 01:56 AM
