Is all B series crank pulley the same???
I got a lightweight crank pulley and I want to put it in. I have a b18b motor and i got a b18c1 GSR lightweight crank pulley. will it fit? Interchangeable?
I've been using a lightened crank pulley for over 2 years on my ls/vtec and have had no problems. I also used one on my last ls turbo and had no problems. But yeah, it will fit. Its just that some are bigger than other so you will have to get the right belt.
Modified by ek99 at 3:29 AM 12/17/2006
It'll fit alright, but i wont go thumbs up with lightened crank pulley, heard some bad stories about unbalanced ones that ate the crank.
Suggest u change the AC/Alt/Ps but leave the crank pulley stock.
i run a JDM SiR2 engine in my 97EK hatch, 2 weeks back the tensioner pulley came loose and jammed my crank pulley eating it in the process. Fixed a B16 pulley, weight wise it was lighter and smaller.
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top »</TD></TR><TR><TD CLASS="quote">this lightweight crank pulley thing has been discussed a repeated amount of times on here.</TD></TR></TABLE>agreed i've heard some bad horror storys about lighter pulleys and i've seen and heard good thing's ....so it up to you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">i have a type-r on mine... stock honda... i like it.</TD></TR></TABLE>
x2 but i have it on a b16b which is very well balanced...
ac, alt, b16, balanced, bseries, crank, crankl, crankshaft, interchangable, lightweight, pulley, pulleys, same, series, unbalanced
