Air/Fuel set up questions???
Old Jan 31, 2002 | 05:18 PM
b18csol's Avatar
Default Air/Fuel set up questions???
im getting so cunfused with the whole air/fuel set ups, especially the fuel. this is newbie stuff but i got to get it straight. If i get aem cold air, Dc Sports twin Canister exhaust, DC JDM header, Skunk2 intake manifold, 01 itr cams, Spoon cam gears, Spoon valvetrain(springs, retainers), ignition, ok so if i have all of that, i am going to need do change my air/fuel. with cams i have heard it is good to get a FPR, do i also need a V-afc, or ecu upgrade? can i use both of those, becaue my computer will be maping out one thing then ill be changing it with the v-afc? then Fuel rail? i do not really understand how to regulate the correct amount of fuel, can anyone please explain to me what mods i can use together and how it will work? or the best mods for this set up i have told above? thanks alot, sorry for all the writing but im still learning and this is what ive been stuck on for awhile, thanks
Old Jan 31, 2002 | 06:14 PM
D-SPEED's Avatar
Default Re: Air/Fuel set up questions??? (b18csol)
a FPR would be good along with a VAFC or even better a hondata.
Old Jan 31, 2002 | 10:06 PM
FitCRX's Avatar
Default Re: Air/Fuel set up questions??? (D-SPEED)
Don't count on us to figure this out...get a A&F meter..and check it yourself
no harm intended
Old Feb 1, 2002 | 02:48 PM
Kataku2K3's Avatar
Default Re: Air/Fuel set up questions??? (FitCRX)
If you really want a good setup to vary ur air/fuel ratio then go with Hondata.
kaj
Jan 21, 2006 12:07 PM
Fink2iCe
Oct 11, 2004 04:20 PM
RAB
Jun 26, 2002 08:45 PM
