aftermarket cams, engine noise
Old Sep 11, 2002 | 08:19 AM
splitime's Avatar
Default aftermarket cams, engine noise
Zex cam, street, 59100.
After install and engine running, it had a clicking sound from the head. I did a valve adjustment and that helped some. Still getting some clicking though, i'm thinking this is from the more aggressive cam profile? Heres a link the the durations:
http://www.compcams.com/catalog/192_193.html
Hum, just noticed something, it shows a setting for the valves. its different than the stock valve adjustment heights for the head, D16z6 head. Should i go back and redo the valve adjustment with these smaller settings listed on the compcam site??
I think he stock valve adjustments are like .002 or more higher.
Old Sep 11, 2002 | 09:43 AM
splitime's Avatar
Default Re: aftermarket cams, engine noise (splitime)
bump
could use some input, will probably do it tomorrow morning on the cold engine, but wanted some feedback first.
Old Sep 11, 2002 | 09:48 AM
Kamin's Avatar
i belive you need to use the settings they give you for the valves.
Old Sep 11, 2002 | 01:45 PM
slooowDX's Avatar
Default Re: aftermarket cams, engine noise (KAMiN)
yup, you need to use what the maker of the cam gives for valve lash settings. i once did a valve adjustment on my Z6 i had b4 using and aftermarket cam lash settings and it clicked like hell
Racewerkz
Jan 26, 2011 07:55 AM
remoer
Jan 21, 2009 12:09 PM
cloudconnected85
Nov 7, 2008 05:23 PM
krazeenoy
Jun 12, 2007 06:26 PM
crashN2u
17
Jul 27, 2004 02:53 PM
