Adding a bypass oil filter
Does anyone have any experience with bypass oil filters? It filters in parallel with
the normal oil filter but at a slower rate. So in theory, the regular oil filter flows as normal while the bypass filter cleans down to 1 micron but at a slower rate. Over time, all the oil will have passed through the bypass filter. Cleaner oil, less engine wear, and longer oil change intervals are the claimed benefits. http://images.zeroforum.com/smile/emsmilep.gif I searched 'micron oil filter' in yahoo and found tons of links. A few are listed below: http://www.amsoil.com/products/bf.html http://www.controlmastersinc.com/ult...oil_filter.htm http://www.oilguard.com/ All of the links had nothing negative to say about the bypass-oil filter setups. But why has this setup never been mentioned here or any of the other auto forums. Does adding a remote oil filter lower oil pressure? Will it take too long warm up the car due to more oil in the loop? I'm thinking about fitting the Amsoil set-up to my car, but don't know if there are any adverse affects. |
| All times are GMT -8. The time now is 03:50 AM. |
