ABS light
Old Jun 5, 2005 | 11:41 AM
Shadow 1992's Avatar
Default ABS light
I have a 92 Accord EX. I will be driving, and if I make a sharp turn (either left or right) or hit a decent size bump, I'll get a constant and steady ABS light. Also I'll get a humming and clicking sound from the passenger side of the engine compartment, and the brake will throb as if the ABS is engaging, this will happen randomly once the light comes on, regardless if I'm turning, stopping, or going over a bump. The only way I can get the light to go away is to turn the car off for a few mintues.
Old Jun 5, 2005 | 12:05 PM
Chiovnidca's Avatar
Default Re: ABS light (Shadow 1992)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadow 1992 &raquo;</TD></TR><TR><TD CLASS="quote"> a constant and steady ABS light. </TD></TR></TABLE>
What trouble code does it have stored?
Old Jun 14, 2005 | 07:45 AM
Okay. Let's make this a bit more difficult. There is no trouble code stored. The car thinks everything is good.
Old Jun 14, 2005 | 01:48 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shadow 1992 &raquo;</TD></TR><TR><TD CLASS="quote">Okay. Let's make this a bit more difficult. There is no trouble code stored. The car thinks everything is good.</TD></TR></TABLE>
ABS codes are a little trickier to check. Jump the service check connector, then turn the key on. The code/s will flash 3 times at the most. Turning the key off and back on should make it run through them again. Should be a code quickly followed by a sub-code.
anomale
Dec 14, 2005 06:10 PM
FatBoy4door
Oct 7, 2004 10:21 PM
xplaya29
May 29, 2004 10:58 AM
Ls-Rturbo
Apr 5, 2004 02:01 PM
RyanAutry
May 3, 2003 02:23 PM
