98 civic d16 NO power on acceleration loping engine
Old Dec 27, 2011 | 03:52 AM
Mobeious's Avatar
Default 98 civic d16 NO power on acceleration loping engine
On my way home yesterday and went to pass someone and started to accelerate and then its like I hit a fuel cut. Then it just got worse missing at all rpm..limped it home .. Checked timing and it was good .. Checked plugs and they were good .. I suspected fuel pump since its been crazy loud last few days but it is feeding fuel to the rail but I haven't actually checked psi .. I did hear a weird washing noise at the fuel rail when I prime the engine.. Could It b plug wires ? Rotor button and cap look good
Old Dec 27, 2011 | 06:07 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: 98 civic d16 NO power on acceleration loping engine
Any check engine lights?
Old Dec 27, 2011 | 06:19 AM
Mobeious's Avatar
Air temp sensor , and bank 1 o2 sensor which I just replaced a month ago so imma swap that out today but that o2 was bad befor and it didn't run like this
Old Dec 27, 2011 | 08:01 AM
riceburner700's Avatar
do you have fuel in the tank?
Old Dec 27, 2011 | 02:17 PM
Mobeious's Avatar
ok replaced .. rotor, cap, plug wires, fuel pump, o2 sensor (bank1)
and did nothing still sounds like a WRX
camshaft pos sensor maybe?
Old Dec 27, 2011 | 03:44 PM
mouab18c1's Avatar
Your air temp sensor is most likely your problem.
Old Dec 27, 2011 | 04:05 PM
Mobeious's Avatar
just changed plugs ... still nothing... i have had my air temp sensor like it is for months with no problems.. my check light is blinking now
Old Dec 28, 2011 | 03:21 AM
Mobeious's Avatar
Does this sound like it could mr the coil?
Old Dec 29, 2011 | 05:31 PM
Dseries_NA's Avatar
It could be also distributor related.. have you tried checking the distribitur and seeing if the ignition coil is good or if anyhthing is burnt... im still trying to figure my hx's problem it does kind of the same thing but not as bad.
Old Dec 29, 2011 | 05:33 PM
Mobeious's Avatar
It was clogged injector filters
Old Dec 31, 2011 | 10:25 AM
eghatchie619's Avatar
howd you know it was the injectors?
Old Dec 31, 2011 | 11:44 AM
Mobeious's Avatar
well i knew i was getting spark and knew the timing was good so only other thing is fuel and i knew i was getting fuel to the rail so i pulled the rail off with injectors still attached and primed the fuel pump and saw that 2 injectors where spraying a stream and not a mist so
cleaned all the injectors pulled gas tank out cleaned inside it and replaced fuel filter and pump filter .. all is well ....... had a bunk of gunk in my tank so im guessing that is what clogged it up
b16a971
Aug 3, 2016 11:40 PM
acmoc
Dec 26, 2015 03:20 PM
x91crxsix
May 20, 2008 09:04 AM
Stew Pidasso
Nov 18, 2003 05:27 AM
