96 Integra Suspension Creaking...
Old Nov 3, 2002 | 07:23 PM
Psychout's Avatar
Default 96 Integra Suspension Creaking...
I have a 96 Integra (Vtec model) and have had this really annoying problem for a while now. Whenever it has been cold/wet outside for a while and I take my car for a spin and go over ANY bump on the road i get a really weird "creaking" noise coming from all 4 wheel areas. I thought it was the bushes but got them checked and they are fine.
Has ANYONE had this problem with the Integra before? The car has only done 100,000 kms so I dont think the shockers would need replacing yet...
Any advice on this problem would be much appreciated
Thanks
Psychout
Old Nov 3, 2002 | 09:40 PM
2camsaam's Avatar
Default Re: 96 Integra Suspension Creaking... (Psychout)
got 1 word for you: WD40
Old Nov 3, 2002 | 11:40 PM
kinesistech's Avatar
Default Re: 96 Integra Suspension Creaking... (2camsaam)
How about some type of lubrication instead. WD-40 is used to break rusted areas free. I wouldnt sweat it.
Old Nov 4, 2002 | 01:50 AM
Psychout's Avatar
Does WD40 react with rubber at all though? and what areas should I focus on for lubrication with WD40?
Have you had this same problem?
Old Nov 4, 2002 | 01:51 AM
Psychout's Avatar
Default Re: 96 Integra Suspension Creaking... (kinesistech)
Shouldn't I be careful that I dont use a lubricant which reacts with rubber?
What lubricant do u recommend?
Old Nov 4, 2002 | 02:21 AM
Pat's Avatar
Pat
If you want to lubricate bushings and stuff, try silicon lube
ososlow24
Dec 28, 2006 05:08 PM
ninjin
Audio / Security / Video
Mar 28, 2006 10:49 PM
