96 Civic Suspension Question?
Old Mar 20, 2002 | 01:41 AM
Fightin'Irish's Avatar
New User
Default 96 Civic Suspension Question?
Looking for some help!
Is it possible that a 96 Civic Coupe(EK) has '95 spec suspension?
Is there a differnece between a '96+ spring and a -'95 spring? (lenght, no.of coils etc.) Is there a difference between a rear Hatch spring and a rear Coupe spring?
Hope you guys can help me out?
Old Mar 20, 2002 | 05:01 AM
DragII's Avatar
Default Re: 96 Civic Suspension Question? (Fightin'Irish)
yeah, it's possible, I swapped springs and shocks from a 93 to a 97....the 97 sat really high afterwards.
Old Mar 20, 2002 | 06:58 AM
New User
Default Re: 96 Civic Suspension Question? (SuperDragII)
I asking this because I want to order some springs/shocks and I'm wondering if I should order '96+ spec. ones or '95 spec ones? I had the shocks out before and I think they had 95 stamped on them?
Old Mar 20, 2002 | 11:00 PM
New User
I take it nobody knows?
Old Mar 23, 2002 | 08:09 PM
n1ek's Avatar
the front shocks are the same fitment
the rear shocks fork is a little wider on the 92-95 civic, you can still run these shocks on a 96, you just have to put a couple of washers on both sides on the lower control arm.
the springs should be different, most likely the rate, with the height being a negligable difference, i would still get the springs for the correct yaer unless you really have your heart set on the eg springs
96ex-honda-kid
Suspension & Brakes
12
May 31, 2012 07:54 AM
Supraznki
Oct 3, 2005 07:14 PM
M0NEYnH0s
Nov 29, 2001 10:58 AM
