95 CX o2 sensor help
Ok im getting a check engine light for an o2 sensor. Tried 2 others and still getting the light and yes i disconnect the battery to reset the ecu. I know it has something to do with the wiring because the check engine light doesnt go away even before I start the car. Its the one wire sensor and i even tried wiring it up right next to the ecu at pin D14 and still get the light. The thing is this car ran a chipped p28 ecu with a 4 wire o2 sensor and didnt have any problems now im running the stock p05 and wired it up for a 1 wire o2 and having problems. I even tried wiring it back to a 4 wire and pluged in my p28 and got the code right away before i start the car. I screwed something up and not sure what. Im almost 100% sure theres no fure for this now im stuck. Thanks for your help
sohc_ef2
Sep 29, 2012 05:34 PM
BrianFreels
Dec 23, 2010 06:06 PM
