92 prelude srs light reset and help
I am rebuilding my 92 prelude si after a front hit, and the srs light is on. before i put the replacement airbags in, how do i reset the light, and do i need to replace the control module as well?
Anytime the airbags in a Honda deploy the SRS module will need to be replaced as well. Disconnect the - battery cable, wait 3 minutes, replace the airbags, replace the module, reconnect and you should be fine.
