92 integra wiring problems
Old Aug 12, 2010 | 01:20 PM
trigger_time's Avatar
Default 92 integra wiring problems
ok i bought a 92 integra obd1 and i had a 91 obdo integra which is totaled . the 92 is a rolling chassis minus the ecu and wiring harness from the outside plugs to the engine . i have bought a obd1 distributor , and had a coulpe of harnesses laying around that i got in a honda parts lot . questions can i use the obdo injectors ? i noticed this harness his no resistor box so what indeopendence do i need in a fuel injector ? i have a p06 ecu which has been converted to run on my b16a hatch which has beeen chipped and i can remove the chip . could i use this ecu for initial start up to ge the engine started and broke in ? i have all this crap done and beleive i have the wiring correct hopefully . engine has been rebuilt and i noticed that inside where the obd1 ecu hooks up there is a wire which is seperate and looks to have been rigged in the past . any help would be great on this .
Old Aug 13, 2010 | 04:08 PM
Default Re: 92 integra wiring problems
anyone??
Old Aug 15, 2010 | 10:24 PM
thegatekeeper14's Avatar
if needed we can make i can make you a tucked harness.
$450
$400 if u send me your core.
heopmarine
Feb 6, 2015 11:24 PM
melo112
Oct 11, 2010 06:37 PM
kylesmith3251
13
Jan 16, 2009 08:17 PM
AIS#4integra
Jan 16, 2006 07:21 PM
