92 eg hesitation to start
Old Mar 17, 2010 | 12:28 PM
  #26
mikeliterus's Avatar
Default Re: 92 eg hesitation to start
yeah. idk i guess i can only stick to trial and error. After i get a new ignition coil ill write back on here and tell u if the problem still persist and if it still does ill check out the injectors, plugs and fuel pressure regulator.
Old Mar 18, 2010 | 11:28 AM
  #27
Circaskaterr's Avatar
we replaced the ignition today and all seems to be well so far hasnt hesitated at all and no missing the old one didnt look like it was in the bad of shape just a lot of rust on the casing
Old Mar 18, 2010 | 11:30 AM
  #28
4g4dcruisin's Avatar
good ****.
Old Mar 18, 2010 | 06:50 PM
  #29
fcm's Avatar
fcm
Old Fart
So have you had it "hesitate" at any time, if you hold the gas peddle to the floor when starting?
At the very least, I would try a new or known working TPS, if for no other reason then to eliminate it as a possibility, a defective sensor would be effected by temperature, a poor connection becomes worse the warmer/hotter it gets. 94
Old Mar 18, 2010 | 08:03 PM
  #30
when i hold the gas peddle to the floor when i start its always starts up. So you think its the TPS and not something like a leaky injector?
Old Mar 25, 2010 | 11:31 AM
  #31
How do you take the TPS off the throttle body?
Old Mar 25, 2010 | 11:57 AM
  #32
smmcla's Avatar
i had the same problem recently. did your tach ever bounce randomly. does it idle rough sometimes. if so its the ignition coil. i replaced mine and walla it worked. but before i replaced it the car wouldn't start at all
Old Mar 25, 2010 | 12:57 PM
  #33
Yes my car does those things but as I said earlier I replaced the ignition coil. I'm starting to think it's a sensor like either my TPS or fuel pressure regulator.
mikeliterus
Apr 7, 2010 09:32 AM
RobEK
Sep 28, 2009 06:30 PM
91rexhf
10
Dec 27, 2008 05:06 PM
bogey883
Sep 6, 2007 02:16 AM
wankerman28
Aug 26, 2007 01:04 AM
