89 Civic DX to SI
Old Sep 28, 2002 | 09:20 PM
koticimage's Avatar
Default 89 Civic DX to SI
I have the d16a6 installed. I just need to find out how to wire in the intake manifold. Does anyone know how to change the DX wiring to the SI? I have the SI ecu and the d16a6 intake manifold and all sensors except the SI TPS. Will the DX TPS work? Thanks for any help you can give.
Old Sep 28, 2002 | 09:36 PM
91DA9's Avatar
Default Re: 89 Civic DX to SI (koticimage)
The DX TPS will work. Did your manifold come with a throttle body?
Old Sep 28, 2002 | 09:46 PM
salbaje's Avatar
you can use your dx tps. hit me up i can help you wire it up. i'm in bay area
Old Sep 29, 2002 | 07:24 AM
koticimage's Avatar
Default Re: 89 Civic DX to SI (94IntegraGSR-OVR)
Yes, I do have the throttle body. Is the TPS's the same or will the DX TPS affect the performance of the new SI engine? I should have everything. I want to just plug in the SI ECU and install the new intake manifold. The only problem, is I don't know how to change the wiring from duel point fuel injection to multi port. Do I have to add some wires and a bunch of stuff? Is it pretty simple? Is there a website that tells you step by step? Thanks for all your help.
E-AT_me
Feb 12, 2008 05:13 AM
91_hatch_si
17
Jan 2, 2003 06:28 AM
xXx Justin xXx
Aug 19, 2002 06:02 PM
simike
Aug 13, 2002 02:50 PM
