6th Gen IACV schematics & a Q
Link to ImageStation Album
Did ALL 99-00 Civic's use different ECU plugs than the 96-98's? As can be seen in the IACV pic's, the 99 D16Y5 uses the same ECU pin-outs as the 96-98's. A quick glance through the ETM shows that a lot of the ECU pin-outs are the same, but obviously not all (the O2 sensor comes to mind quickly).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Link to ImageStation Album
Did ALL 99-00 Civic's use different ECU plugs than the 96-98's? As can be seen in the IACV pic's, the 99 D16Y5 uses the same ECU pin-outs as the 96-98's. A quick glance through the ETM shows that a lot of the ECU pin-outs are the same, but obviously not all (the O2 sensor comes to mind quickly).</TD></TR></TABLE>
Yes.
99-00 = OBD2.5
96-98 = OBD2
Some are the same through OBDI to OBDII howerever, there are slight changes.
Yes.
99-00 = OBD2.5
96-98 = OBD2
surkitroller
Apr 15, 2005 05:05 AM
EX-T
Dec 14, 2003 06:25 PM
igo4bmx
May 31, 2003 05:38 PM
