65-60mm T/B, Any performance gain?
Old Sep 20, 2004 | 11:14 PM
Traction's Avatar
Default 65-60mm T/B, Any performance gain?
I am able to pick up a throttle body (stock d16) that has been bored with the outside diamter being 65mm and the diameter directly infront of the butterfly is the oem 60mm
Would I see any gains from this?
Thanks
Modified by Traction at 4:52 PM 9/21/2004
Old Sep 21, 2004 | 07:52 AM
Traction's Avatar
Default Re: 65-60mm T/B, Any performance gain? (Traction)
Old Sep 21, 2004 | 08:31 AM
civic-4-ges's Avatar
You won't neccessarily see a "gain" from this, but you will however see an increase in throttle response. All the larger throttle body will do is allow more air in sooner.
Old Sep 21, 2004 | 12:53 PM
HONDA_TYPE_R's Avatar
Default Re: 65-60mm T/B, Any performance gain? (civic-4-ges)
You may see a slight gain, but it will be more or less seat of the pants. The more mods you have, the more of a difference the TB will make.
mtber
Feb 2, 2010 06:17 PM
skipper_red
Honda Civic (2006 - 2015)
Nov 3, 2009 12:28 AM
k20coupe
Jan 19, 2009 12:02 PM
chunkybs
Oct 20, 2007 11:56 AM
