4puck or 6puck
Old Jun 8, 2005 | 11:31 PM
MR. BAR's Avatar
Default 4puck or 6puck
wuts the difference between a 4puck and 6puck clutch, say act has the xtreme with a 4puck and a 6puck they both have the same torque rating and only cost about $20 difference(6puck being more expensive). wut is the difference in performance and quality?
Old Jun 9, 2005 | 01:22 AM
flip1199's Avatar
Default Re: 4puck or 6puck (510gsrhatch)
4 puck has a rougher engagement. Kinda depends on your tranny also. my friend has a act 4puck in his b16 crx and it's kinda bitch to drive. chirping tires every time i take off or stalling out. But i have the same 4puck in my prelude and it's alot smoother. i'd just stick with the 6puck.
Old Jun 9, 2005 | 08:37 AM
blacksihatch's Avatar
Default Re: 4puck or 6puck (flip1199)
Your right you can get a rougher engagement with the 4 or 6 puck if not spring loaded if you can get either one with the springs on them(cluchmaster FX400 for ex) you will have much smoother shifts between gears... and the 6 puck would still be smoother than the 4 puck in either instants.........
Old Jun 9, 2005 | 06:32 PM
LSVTEC 91 Civic's Avatar
Banned
6 Puck if this car is your daily driver, 4 puck if it is your track *****.
Old Jun 9, 2005 | 07:34 PM
Kendall's Avatar
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">6 Puck if this car is your daily driver, 4 puck if it is your track *****. </TD></TR></TABLE>
Full disk if it's a daily driver, 6 puck if it's a track *****, 4 puck if you plan on drag racing the **** out of it.
Old Jun 10, 2005 | 07:36 AM
builthatch's Avatar
MiG-21 superfan
a 4 puck is harder to slip vs. a 6 puck, however, is usually lighter.
Old Jun 10, 2005 | 07:38 AM
tgreaves's Avatar
Also the 4 puck will be able to hold more power than the 6 puck..
Old Jun 10, 2005 | 02:51 PM
sir boostalot's Avatar
Default Re: 4puck or 6puck (tgreaves)
i got a 6 puck ACT HD, its daily driveable.
I wouldn't go over a 6-puck if it would be used for everyday driving. 4-puck could also get premature wear if you don't take care of it while daily driving.
Old Jun 10, 2005 | 05:33 PM
cpforyou's Avatar
Default Re: 4puck or 6puck (sir boostalot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sir boostalot &raquo;</TD></TR><TR><TD CLASS="quote">i got a 6 puck ACT HD, its daily driveable.
I wouldn't go over a 6-puck if it would be used for everyday driving. 4-puck could also get premature wear if you don't take care of it while daily driving.</TD></TR></TABLE>
I've had both the ACT 4 Puck ad the 6 Puck. I like the 6 Puck better. It's easier to drive daily, and holds its own on the tracks just fine.
Old Jun 10, 2005 | 06:36 PM
Default Re: (Kendall)
his 2 options are the 4 or 6 puck my bratha.........
Old Jun 10, 2005 | 07:24 PM
Kendall's Avatar
Default Re: (blacksihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksihatch &raquo;</TD></TR><TR><TD CLASS="quote">his 2 options are the 4 or 6 puck my bratha......... </TD></TR></TABLE>
Yes, but why limit yourself.
Old Jun 11, 2005 | 03:04 AM
illegalgarage's Avatar
I know this guy down in san jose (superior clutch) he makes clutches for some of the local shops
for daily driver you should probably get a custom full disk set up sprung hub
but he also does 4 puck, 6 puck, 3 puck (like TRD), and he has a secret 5 puck he is working on
Max
Old Jun 11, 2005 | 03:40 PM
Kendall's Avatar
Default Re: (illegalgarage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illegalgarage &raquo;</TD></TR><TR><TD CLASS="quote">I know this guy down in san jose (superior clutch) he makes clutches for some of the local shops</TD></TR></TABLE>
There's also a guy local to me that runs a similar business. I ran one of his full disk setups in my last hatch and it was better than any other aftermarket clutch I've been able to find.
ih8sndq
Jan 2, 2007 01:52 PM
San-Wan
Oct 13, 2006 07:40 PM
JDM00SI
Oct 26, 2005 03:08 PM
BlackLudeSi
Apr 29, 2005 02:20 AM
