from 17's to 16's using coilovers. do i need a ALIGNMENT? help
i use 17s on my car, and for winter i put on some 16's wit winter tires. do i need to align my car everytime i change the wheel sizes? or raise or lower the car a little using coilovers?
everytime you raise/lower your car you should go get it aligned, just so you dont have camber problems down the road
I do the same thing, though I go from 17s to 15" snowies. No it won't effect the alignment, at least not enough to be of concern. If you raise or lower it a large amount it will change your camber, and should theoretically be re-aligned. Small ride height changes won't make huge differences however. As always keep an eye on tire wear when tinkering with these things. Abnormal tire wear could be a sign of an alignment problem.
jxhxb
Suspension & Brakes
Jan 9, 2009 10:51 AM
Kangolbrand
Suspension & Brakes
10
Nov 28, 2006 09:23 PM
EL'ation
Sep 28, 2002 01:11 PM
