11:1 too high on 91 octane?
did a search. some conflicting information. i've heard that 11-11.5 can be gotten away with. timing will of course have to be retarded. would anything else help?
what about 93 with 11:1 and 18BTDC, stock GSR head and stuff with ITR block, stock HG, NGK OEM ITR plugs 6 heat range 11 application code
b18-ej1, what kind of chip are you using?
sparkz, how is the skunk2 program set up?
i have a chip too but its a mystery as to what its parameters are. it has fuel maps to rev to 9000 and no rev limiter. i know it added torque and probably a couple hp. if i can run higher compression than 11:1 then i'd like too. if i use a .062 head gaket that would put me at ~11.25:1. have to mill the head to go higher. should i use colder plugs too? thanks
Guest
Posts: n/a
I think I'm going back to either PYR or XS Engineering. I also have a G-Force that I want to try, and I got a mugen, Jun, and I think a Spoon chip here somewhere.
Go with Hondata and proper tuning. You'll get away with more than that. Plus you won't drink gas like it's going out of style. I've run the chips for awhile because the Hondata systems were too much. Realistically though if you factored in fuel cost, the Hondata would be much cheaper after 6 months.
Austin
p.s. I'm also running 290cc/min injectors because I ran out of fuel.
Guest
Posts: n/a
Still waiting for the Skunk2 manifold to get CARB approval, and I'm going to install a set of 63402 crowercams.
I like it. What compression are you running? Sounds like we'll have nearly the same setup. BTW I would not have you get the Hondata 2d setup. Get the new S200 setup. If you already have a socketed OBDI conversion then the cost would be just over 1/3 that from the guys at hondasaver. Not sure if they'll get mad at me for posting the price.
They'll build you a base map, then you can tune it when you get all your stuff in. That's what I'm doing. Good luck whichever path you choose bro.
91 octane; 12:1 with base timing @ 5-8 btdc, all of it it tune dependent. also remember, your camshaft selection can lower your dynamic compression significantly. So you might have 13:1 pistons (static compression #), but due to the valve overlap induced from your cam, it's equivelent to have 11.8:1
[Modified by builthatch, 5:48 PM 9/25/2002]
Hope you had a gas can! J/K
Can you tell us more about your setup?
https://honda-tech.com/zerothread?id=269935
Austin
I can't afford the $600+ price tag for the 2dn and tuning. Besides that, I'm not done installing parts.
Austin
Guest
Posts: n/a
Since you already have an OBDI ecu the cost would be $300 plus a couple of bucks to make sure that your ecu was socket correctly for Hondata.
Austin
Austin
2Dn = $545
+ Dyno time.
Guest
Posts: n/a
S200 with datalogging and romeditorV3 = $695
OUCH!
Yessir, but the new S200 us modular in design. You can add the stuff you wan't whenever you want, without even sending the unit to them. Great design IMO. If you go to an experienced Hondata dealer, they should be able to burn you a base map to get you by for now. Finish your motor building, then get it tuned properly. You can add datalogging and get a rom burner whenever you want.
IHow do you figure?
2Dn = $545
+ Dyno time.
2Dn = $545
+ Dyno time.
Austin
Very nice. Any plans for further mods?
Austin
nice. my buddy just put in a 98+ JDM ITR tranny in his GSR. The 4.785 in the USDM ITR tranny would be a sight to behold in your car bro... 200whp and tight ratios... LSD... beautiful.
anywhoo. an update. I dynoed a baseline today, 158/121 w/120 at 5252rpm
SAE corrected. GSR head/cams/valves/HG/ARP studs, ITR block/valvesprings/LMAs/Ti retainers, GSR manifolds/fuel/ecu, exhaust,
fresh air to stock intake and ITR muffler. complete with glow in the dark
header
the dyno revealed me to be in the 15.7-13.7 range from
3-8K. I guess this is a bit lean, but acceptable for now
maybe I should finally add my mugen temp controls and B&M FPR kit and dyno tune it a couple runs on oct 5th.
header
the dyno revealed me to be in the 15.7-13.7 range from3-8K. I guess this is a bit lean, but acceptable for now
15.7!! dude, "a bit lean"? that is waaaay tooo lean! I would be really scared of somethings happening, you're egt's are prolly thru the roof, fatten that bitch up alot and you'll see your motor alot longer and gain significant HP.
Yamashita Say: "glowing heada nota good for mota"
Jared Say: "youre goddamn rite bro!!!"
[Modified by builthatch, 8:51 AM 9/26/2002]
