@pros: from which model is this throttle body
Old Feb 23, 2004 | 07:35 AM
germanEE8's Avatar
Default @pros: from which model is this throttle body
Hey,
got a question for the pros here
Somebody offered me a throttle body. He says it has about 2.5" Diameter where its mounted to the intake. He had this throttle body installed on a h22 intake manifold, but doesn't know where it came off. There is a little yellow sticker on it that says 10AO .Who knows from which model this tb came off and whether it fits a itr manifold?
big thx in advance!
greetz
marc
Old Feb 24, 2004 | 04:16 AM
germanEE8's Avatar
Default Re: @pros: from which model is this throttle body (germanEE8)
Found a picture of the described throttle body. Does anyone know now?
thanks,
marc
Old Feb 24, 2004 | 07:34 PM
chameleon's Avatar
that is a stock H22 TB. they will all fit between H series and B series, i believe its the same diameter as a B16 TB since i matched them up before to check the sizes but that was from the inlet not the IM opening size. i would not get that TB because its a pre 95 H22a and they didnt have the MAP sensor on the top. they came on the firewall on the preludes.
Old Feb 25, 2004 | 01:56 AM
germanEE8's Avatar
Default Re: @pros: from which model is this throttle body (chameleon)
Hey,
thanks for your reply. Hm, I'm running a CRX EF8 and my Mapsensor is @firewall, too I think. So this shouldn't be a problem.
How big can you bore a H22 tb?- I need a 64-65mm tb for my new intake manifold and don't want to spend hundreds of $ for a aftermarket tb. My friend can bore the tb out for me and cut me a new butterfly for a few beers. So I just need a good stock tb, that I can bore out...
greetz
marc
spaazm
Jun 25, 2011 06:32 AM
Xtream_V
May 30, 2011 06:41 AM
IgnitionZ055
Oct 4, 2010 10:29 PM
DC5mike
Dec 1, 2007 05:15 PM
gavhowe
Apr 22, 2002 07:18 AM
