would this work
Hi guys,
i did a search and couldnt find an answer....well i have a 99 civic hatchback and will do a rear drums to discs conversion using 95 GSR rear brake discs with their trail arms, but i started to get frightened here when i ordered Ksport suspension for my car and know the front will fit, but dont know if am gonna have problems with the rear? just need clarification if the civic coilvers will work with the rear gsr brake conversion?
thanks in advance guys!
Km
Km
um if you keep you are stock civic trailing arms you should be ok, but if you using the gsr trailing arm youll have to shave down the metal part of the shock mount. id say just use your stock civic lca.
this what i have to be more accurate:
1-95 gsr rear brake disc conversion that includes trailing arms
2-ksport suspension with matching Ksport LCA's (both are for civic application)
now will i have problems here?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraTypeR »</TD></TR><TR><TD CLASS="quote">this what i have to be more accurate:
now will i have problems here?</TD></TR></TABLE>
you should be fine with that
vtec-adykt
Jan 27, 2005 07:13 PM
Jul 15, 2003 09:57 AM
Boostin Ex
Jan 7, 2003 11:30 PM
SoloSol
Mar 4, 2002 02:51 PM
