Suspension & Brakes Theory, alignment, spring rates....
wobbly
Old May 23, 2009 | 09:20 PM
jimmy051702's Avatar
Default wobbly
when i turn the wheel while driving the car moves to one side then when i turn back the car like swerves really bad dont know if im explaining it right or not but when i go over bumps seems like something is loose on the driver side like a click to and when i get on the car the steering wheel will sway kind of and have to hold it strait. o and one more thing when i am driving at about 60 or so the car sometime will like sway over to one side and i have to hold the steering wheel strait what can i do to check it if i explained it right kind of hard to put into words i guess
Old May 24, 2009 | 12:50 PM
Default Re: wobbly
no body?
Old Sep 1, 2009 | 10:45 AM
ethereal2pt2's Avatar
Default Re: wobbly
bump, i'm kind of having the same issue.
Old Sep 1, 2009 | 12:50 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: wobbly
check bushings and ball joints.
Old Sep 3, 2009 | 03:27 AM
.Manny.'s Avatar
Touching My Member
Default Re: wobbly
have you jacked up the car to check anything?
Old Sep 3, 2009 | 06:28 PM
sacicons's Avatar
Default Re: wobbly
I think I'm having the same problem. It feels like there is a lot of play at the center on my steering wheel. when i change lanes and hit the little reflectors, it jerks more than it should, and the steering gets VERY vague under hard acceleration. it has jerked me out of my lane at times. the worst part is, it all started after my last alignment. the numbers on the printout look ok, except my rear toe that doesnt have enough adjustment, but the numbers were worse before the alignment. Ive been underneath it a dozen times trying to find the problem. the only thing Ive found is a bad front wheel bearing, replaced that, and it still does it.
canadianSIR-G
Nov 9, 2005 10:27 PM
GSR-T-
Aug 5, 2003 09:31 AM
cohenr
Aug 26, 2002 06:52 PM
