Suspension & Brakes Theory, alignment, spring rates....
tein flex + edfc?
Old Feb 1, 2005 | 06:40 PM
The Phil's Avatar
Default tein flex + edfc?
i'm thinking of getting the tein flex coilovers with edfc for my 94 prelude...does anybody have these on their car (prelude or not)?
are they any good?
Old Feb 1, 2005 | 11:08 PM
IntegraBoy04's Avatar
Default Re: tein flex + edfc? (xthephilx)
hoehouseworker has the Flex on his lude...PM him about it.
Old Feb 4, 2005 | 06:49 AM
Electron_LS-Vtec's Avatar
well finally thank god... someone that has a good idea.... go for the flex. my friend has the flex in his EP with the EDFC and it kicks ***! you still need to do some more mods i.e. sway bars but other than that you will be very happy with your decision!
good luck
Old Feb 4, 2005 | 08:08 AM
The Phil's Avatar
Default Re: tein flex + edfc? (Electron_LS-Vtec)
thanks...i've been looking at the flexes (flexs?) for a long time
cant wait to save up to get them...i have like $1 so far
Old Feb 4, 2005 | 02:13 PM
luudog55's Avatar
They are great for the street. You will be very happy when you put them on. You don't need to waste money on the EDFC. Just spend it somewhere else. My friend has the EDFC and says its not worth the money, just pop your hood and trunck and turn the *****.
Old Feb 14, 2005 | 01:10 PM
wraith_em2's Avatar
Default Re: tein flex + edfc? (luudog55)
What about on a car where the rear two aren't easily accessible without removing the back seats? Do you think it's worth buying then?
Old Feb 14, 2005 | 01:17 PM
bad-monkey's Avatar
Default Re: tein flex + edfc? (wraith_em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wraith_em2 &raquo;</TD></TR><TR><TD CLASS="quote">What about on a car where the rear two aren't easily accessible without removing the back seats? Do you think it's worth buying then?</TD></TR></TABLE>
depends on whether the 300 bucks it costs is worth it to you to not have to remove your backseats.
the flex's are ok, but the OE spring rates from tein kinda suck. 10kg F/6 (or 7)kg R.
for a prelude, i'd skip the EDFC. get a progress adj rear sway instead.
Old Feb 14, 2005 | 03:44 PM
Mikes01GSR's Avatar
Default Re: tein flex + edfc? (bad-monkey)
Do people find these to soft for a track day every now and then?
Old Feb 14, 2005 | 09:04 PM
mike-y's Avatar
Default Re: tein flex + edfc? (Mikes01GSR)
not too soft, but poorly matched spring rates. for an integra, its like 9k/4k. very stiff up front, and kinda soft in the rear. makes the understeering problem a FWD car inherently has worse. and the 16 adjustments aren't all that usable. I found that I was stuck in a much smaller range of clicks that were usable without the car getting too bouncy.
Old Feb 15, 2005 | 08:36 AM
Mikes01GSR's Avatar
Default Re: tein flex + edfc? (mike-y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike-y &raquo;</TD></TR><TR><TD CLASS="quote">not too soft, but poorly matched spring rates. for an integra, its like 9k/4k. very stiff up front, and kinda soft in the rear. makes the understeering problem a FWD car inherently has worse. and the 16 adjustments aren't all that usable. I found that I was stuck in a much smaller range of clicks that were usable without the car getting too bouncy.</TD></TR></TABLE>
Thanks for the information, so getting some stiffer rear springs and revalving wouldn't hurt then? I have the teins and being my car is multipurpose, dailey,
open track days, drag.....the flex fit me the best, I haven't had them on the road
course yet so I didn't know what to expect. Anyone else?
Old Feb 15, 2005 | 09:12 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR &raquo;</TD></TR><TR><TD CLASS="quote">
course yet so I didn't know what to expect. Anyone else?</TD></TR></TABLE>
i would definitely go with new springs. how stiff is up to you, i've got 450/550 on my car, but my car weighs 300 lbs more than a dc2 so, my wheel rate isn't so high.
i would think something around 7k front 9k rear would be ok, whether you need to revalve the rear dampers to put the 9k front springs on the rear, i don't know.
Old Feb 15, 2005 | 12:50 PM
mike-y's Avatar
stiffer springs would definately help, but tein only recommends up to a +2k increase before revalving. so you could run 9k/6k and still be withing tein's specs. you could go a little softer up front for a better f/r ratio, but then you will bottom out the shock a lot easier. The flex's really didn't have much overall travel, and bottoming was an issue for me on some of the tighter corners.
and if you need revalving, you might want to consider a set of konis and ground controls with the exact spring rates you want to run. the damping curves on the konis are also more street friendly, and will ride smoother, even on stiffer spring and damping rates.
hrdsktr1988
Honda Civic (2006 - 2015)
Sep 27, 2009 10:23 AM
CivicInspired
Honda Civic (2001 - 2005)
22
Jul 18, 2007 08:01 AM
crapanese
Jun 25, 2006 07:21 AM
lsturbo44
Suspension & Brakes
Apr 3, 2005 10:11 PM
AsnRefugee
Jan 14, 2004 08:48 AM
