suspension problem
i recently got my old oem struts replace and got me some tokico adj. but the problem is that my front bounces alot, my car felt better with my old oem strut, my current set up is ground control coilovers and tokico struts, is there any way i can make my suspension stiffer, i drive a 89crxhf
did you go from oem shocks and springs to GC/illuminas?
when i first installed eibach prokits and illuminas at the same time, the ride totally changed and i was initially uneasy about the "stiffness" of it all. but i got used to it. basically, you put stiffer springs in your car, and normal GC spring rates are even stiffer. so you need to expect that. theres nothing wrong with your shocks or springs.
5 is greater damping, 1 is less. when i had set everything at 1 with prokits, the ride was almost like a cadillac. i think i hovered around 4 front and 3 rear on the street. but thats with prokits, not linear rates like GC and stiffer.
if you want a softer ride, buy softer springs.
