Struts??
Good day.
My son wrecked my '98 accord LX sedan, ran up on a curb ended up in bushes. It's been repaired but there's a new issue that has arisen. The car got new tires, wheels, something w/ the axle on the passenger side, alignment, new passenger side fender and wheel liner.
Now the car "squeaks" as its being driven, or even standing still when the tires are turned either way. My neighbor says w/ the accident, the struts may need to be aligned or replaced and the body shop should do it.
Before I call/go back to the body shop, I'd like your opinions.
Thanks.
Thanks.
I assume they checked the rest of the suspension when they made the repairs. But to check the shocks press down on the front of the car at each wheel and listen for a squeaking sound as it bounces. If it bounces excessively (more than once or twice) they shock(s) may be bad. If you can jack the car up you should check the control arms to make sure they arent bent, the tie rods and steering rack. Does the noise only occur when you turn the wheels or does it happen while driving straight?
Good day.
Thanks.
Thanks.
hudalarious
Suspension & Brakes
Jul 16, 2012 01:51 PM
skunk2eg
Feb 21, 2009 05:07 PM
