Suspension & Brakes Theory, alignment, spring rates....
Spring Clocking?
Old May 14, 2010 | 12:57 PM
RustyE.G.'s Avatar
Default Spring Clocking?
I've got some Koni Yellows I'm about to install. Since the spring perches are adjustable and freely rotate, does it matter how the spring is clocked when installed? Should I try and match it to the position of the factory spring perch? On a side note, does anybody put anti-seize or anything else on their perches to keep the from rusting/seizing up? The midwest sucks.
Old May 14, 2010 | 07:32 PM
RustyE.G.'s Avatar
Default Re: Spring Clocking?
bump
Old May 15, 2010 | 09:50 AM
civicjason's Avatar
you dont have to worry about clocking them, the spring purches will not sieze and there is really nothing you can do to stop the rust from happening.
Old May 19, 2010 | 03:43 PM
RustyE.G.'s Avatar
Thanks for the reply, I'm finally getting these put together tonight. About the seizing I wasn't referring to the perches themselves, but the "snap" ring they sit on. Those tend to rust in place I hear. I doubt I'm going to adjust them again after I find the height that I like, but I think I'll put some anti-seize on them anyway.
jdmwannabe813
Suspension & Brakes
Jan 3, 2012 10:29 PM
exgr
18
Oct 29, 2010 02:14 PM
DA is best
Suspension & Brakes
Jul 7, 2007 11:15 PM
bosco500
Jun 8, 2005 05:32 AM
01nhbgsr
Feb 23, 2004 03:47 PM
