Suspension & Brakes Theory, alignment, spring rates....
Rear Disk Conversion On EG?
Old Jul 15, 2006 | 10:41 AM
blks2k3's Avatar
Default Rear Disk Conversion On EG?
I have rear disk brakes off of a 94 del sol that I am putting on a 92 hatch. I know I need the ebrake cables off of 99-00 civic or 94+ integra. My question is do I need to use the proportional valve and master cylinder off the del sol or will it be alright not to change them.
Old Jul 15, 2006 | 07:57 PM
XkjeldorX's Avatar
Default Re: Rear Disk Conversion On EG? (blkgsr3)
i only added the rear disk to my cx hatch and didnt change th prop. valve or MC/BB and brakes awsome. if u plan on upgrading the front brakes than it is recommended or pedal feel is going to be sluggish.
Old Jul 16, 2006 | 09:08 PM
o5mar1's Avatar
at least replace your proportioning valve, the one you have now is made for rear drums wich uses different pressures than disc brakes.go to your local junk yard and get one off of any non abs civic or integra. i got mine for like 25 dollars
Old Jul 17, 2006 | 05:44 AM
rwcdrums's Avatar
Default Re: (o5mar1)
I upgraded my fronts to gsr's but left the rear drums. Do I need to prop valve?
Old Jul 17, 2006 | 12:34 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (rwcdrums)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rwcdrums &raquo;</TD></TR><TR><TD CLASS="quote">I upgraded my fronts to gsr's but left the rear drums. Do I need to prop valve?</TD></TR></TABLE>
No you don't. The 93-95 2 door EX Civics use the same exact prop valve as the other rear drum EGs, but they have larger 10.2" front brakes...
Old Jul 17, 2006 | 03:36 PM
rwcdrums's Avatar
Default Re: (94eg!)
I<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">
No you don't. The 93-95 2 door EX Civics use the same exact prop valve as the other rear drum EGs, but they have larger 10.2" front brakes... </TD></TR></TABLE>
Well I got a 92 cx does this still apply?
Old Jul 17, 2006 | 09:35 PM
94eg!'s Avatar
#1 Super Guy
Loved
Uh, yeah...
The reason I say specifically the 93-95 Coupe, is because there was no coupe sold in 92...
lexusman83
Apr 10, 2009 01:35 AM
dj theoretic
May 24, 2008 07:37 PM
Bulli Kid
Jul 9, 2007 07:03 AM
vadersi
Suspension & Brakes
Apr 25, 2005 01:32 PM
arcsec
Nov 23, 2002 11:55 PM
