Suspension & Brakes Theory, alignment, spring rates....
question: ground controls
Old Sep 24, 2008 | 07:58 PM
Lextasy's Avatar
Default question: ground controls
ok maybe stupid question but if i bought gc's that fit oem, tokico, kyb, etc.... is there any way that I would be able to switch to koni in the future or would i have to buy brand new gc's?
Old Sep 24, 2008 | 09:59 PM
garados's Avatar
Default Re: question: ground controls (Lextasy)
i'm pretty sure that you can get the koni adapter to fit over the c-clip, but I'm not too sure. If it is that easy, you get these aluminum adapters that fit into the bottom of the GC sleeve and the adapter has a little ridge cut out of the center to go over the clip and you'll have a "true coilover system!" MUAHAHAH!! ... uhhh, that is if it's that easy
Old Sep 25, 2008 | 06:01 AM
gabebauman's Avatar
Default Re: question: ground controls (garados)
I would contact Ground Control. They should be able to sell you the sleeves individually.
https://honda-tech.com/zerothread?id=2141882
Old Sep 25, 2008 | 02:39 PM
GroundControlTrevor's Avatar
Default Re: question: ground controls (gabebauman)
We sell a conversion kit for koni, new threaded sleeves, and new spring perches. everything else you have you reuse. The new sleeves and perches are specifically for koni.
Old Sep 27, 2008 | 02:12 PM
thumper64's Avatar
Default Re: question: ground controls (GroundControlTrevor)
Konis and others use different kits? Crap. How much is the kit for a 92-95 Civic?
Old Sep 27, 2008 | 09:18 PM
DcLs's Avatar
no you would not have to..i bought my GC first and drop them on oem shocks..6 month later i bought some koni yellows and they fit just fine..just make sure u take off the brake line adapter and put them on the konis..
Old Sep 28, 2008 | 07:51 AM
thumper64's Avatar
Well if what you say is true, you just saved me at least $50.
dxlol
Suspension & Brakes
Oct 21, 2010 02:09 PM
PowerLeg
Suspension & Brakes
Aug 19, 2008 06:22 PM
guero2craze
Jan 11, 2007 12:07 PM
Civicman86
Suspension & Brakes
May 6, 2005 04:33 PM
89civicdx
Jul 8, 2001 02:21 PM
