Suspension & Brakes Theory, alignment, spring rates....
please a need help??????
Old Apr 27, 2010 | 08:14 AM
msotenojdm's Avatar
Default please a need help??????
I need help with my car I owened a 93 hatch I took the car to get an alignment and the guys told me my front wheels werent straigh. the left tire is 4 finger from the tire to the fender and the right tire is 3 fingers.so they are not straigh. Before I used to had the stock schocks and they were blown and i did not had this problem, I recently install some lotek shocks that a friend gave me brand new. another question is how tie should the shock be to the lower control arm...??? any help would be apreciated.
Old Apr 27, 2010 | 08:55 AM
96hb's Avatar
Default Re: please a need help??????
Sounds like you may have something bent under there. Has the car ever been in an accident? Also check your tie rod ends, ball joints, bushings, etc. It could be about any number of things. The alignment tech didn't check it out and give you some sort of idea of what the problem was?
Old Oct 27, 2010 | 12:32 AM
estewar03's Avatar
Maybe one of the lotek struts is bad on that side.
tl4u2c
Jul 24, 2006 07:06 PM
fastest
May 24, 2004 09:46 PM
89dohcEF
Oct 11, 2003 08:20 PM
89sir-9
Dec 14, 2001 01:44 PM
Rah Rah
Nov 7, 2001 06:37 PM
