one side lower?
i just lowered my car, and then the next day i hopped on a curb with my front left side. now i look closely, and my front right is dropped about a .25-.5 inch more than then my front right. im not shure if this was before or after the curb incident. is this normal?
the only other things i notice after jumping the curb is that my alignment is a little bit off(more off actually), and my wheel is no longer centered, its a tiny bit to the right.
The car won't be level left to right, the wieght is not even. Thats normal. However, if its even more off after jumping a curb, check for damaged parts. Also, if you bottomed the shock hard enough, I suppose there's a chance that you pushed the front shock down into the fork. Check both sides to make sure that the shocks protrude down below the fork the same amount.
DC2-ProdUcTiOnS
Jun 3, 2009 10:42 AM
