Suspension & Brakes Theory, alignment, spring rates....
need advice, which setup.
Old Jan 24, 2005 | 03:50 PM
projectPSI's Avatar
Default need advice, which setup.
did my research, didn't find exactly what i was looking for.
Up grading my suspension on my 94 teggy. (brakes, sway, struts, etc.)
Have a few choices plz let me know pros cons to each.
TOKICO Coilover Kits
TOKICO Illumina shocks, groundcontrols.
Koni Yellows, ground controls.
Koni Threaded suspension kit.
Old Jan 24, 2005 | 06:47 PM
travis's Avatar
Default Re: need advice, which setup. (projectPSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectPSI &raquo;</TD></TR><TR><TD CLASS="quote">
Pros and cons of what? A "pro" for one application might be a "con" for another. What are you trying to accomplish with your new suspension (and don't say "better handling")?
Old Jan 26, 2005 | 05:16 AM
projectPSI's Avatar
Default Re: need advice, which setup. (travis)
Looking for a setup for a daily driver, want adjustable shocks so i can make em a little stiffer when i ocasionaly take it to the track. The car is going to be a ls vtec turbo setup so ill be making a small amount of power.
Old Jan 26, 2005 | 05:58 AM
artifex's Avatar
say it
what are your ultimate goals for the car? will it always be a DD? slowly turning it into a HPDE car? autocross? do you want a nice smooth ride? do you want to handle?
i've driven my car (obviously) with the GC/Koni 400f/450r for three years over shitty chicago roads, and while it can be obnoxiously stiff over really crappy roads, the handling improvement over stock makes it worth it. I've also driven a slightly faster GSR with GC/ Illumina setup, with GC-spec spring rates, and the car drives nice and smooth, and handles nicely, but not as nicely.
OTS Konis can handle higher spring rates (~600 lbs/in) than most other "performance" shocks on the market. They can also be revalved, shortened, converted to double-adjustable, all without international shipping.
what is really comes down to is what you ultimately want to do with the car, and how much of a beating you can take daily (if your roads are not so smooth)
FTW
Honda Civic (2006 - 2015)
Apr 24, 2008 11:57 PM
4 door GSR
Dec 4, 2007 02:32 PM
white99CF
Jun 9, 2007 04:50 PM
lsracer27
Suspension & Brakes
11
Dec 17, 2005 07:09 AM
alacard
Suspension & Brakes
29
Sep 13, 2005 03:30 PM
