Suspension & Brakes Theory, alignment, spring rates....
Koni strut problems
Old Apr 30, 2007 | 05:27 AM
MNsnowdaboy's Avatar
Default Koni strut problems
I bought myself a set of used Konis and they still work good until recently.....I think. Well no matter what the setting is I find the front struts keep getting softer. I realize that the **** on the strut keeps popping up. Is this normal? If I press it down the suspension gets stiffer again but after a while and hitting a few bumps they get soft again and sure enough the **** pushes up again. My rears doesn't do this.
So anyone knows what is going on or is it normal?
Also how much do you tighten the nutz down? I just kepting tighting the first nut until it got hard but it still kept going but harder and harder. I stopped after a while and just use the other nut to lock it in place. (see pic 2).
PIC 2.
Old Apr 30, 2007 | 06:12 AM
be.twenty's Avatar
don't think it matters but the first pic shows a nut that doesn't look like it belongs - also the first pic shows that the area seems moist.. might just be the pic though.
Old Apr 30, 2007 | 02:27 PM
Yeah I know but hey I couldn't find the right nut.
So how much do you guys tighten the lower nut down? until it stops or how low?
Old Apr 30, 2007 | 03:39 PM
Rzoops's Avatar
Isn't that c-shaped washer that is right below the two nuts upside down? I thought it was supposed to sit like \___/
Old Apr 30, 2007 | 04:07 PM
Tyson's Avatar
Default Re: (zoops)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoops &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that c-shaped washer that is right below the two nuts upside down? I thought it was supposed to sit like \___/</TD></TR></TABLE>
it is supposed to fit like a cup.
wtf is up with that first pic? couldnt find the right washer?? i dont get it...
how about calling koni for customer service...?
Old Apr 30, 2007 | 04:53 PM
Yeah just too lazy to get the right washer.
About the ****, does your sit flush or raise like in pic 1???
Old Apr 30, 2007 | 05:58 PM
chrisw85's Avatar
Default Re: (MNsnowdaboy)
my adjuster pops up like that on two of my shocks, one seeps which is normal per 'crx lee' @koni. I dont notice a diff with it up or down. the adjuster works just fine on either shock.
the seeping is because sometimes when they are rebuilt (mine are rebuilt with spss valving) the little tiny seals that seal the adjuster rod get slightly misaligned or nicked ever so slightly to allow oil to seep but not cause a blown shock effect.
uratom
34
Aug 26, 2008 01:18 PM
Mark D. Surface
May 14, 2007 05:51 PM
anngsr
Jun 7, 2004 12:11 AM
gsr1997integra
Oct 24, 2001 01:15 PM
