Suspension & Brakes Theory, alignment, spring rates....
Koni GC problem...
Old Nov 23, 2009 | 08:34 AM
  #26
blaze the chemi's Avatar
Default Re: Koni GC problem...
Originally Posted by hialeahzbg
Do I have to cut the bumpstops in half? I saw a diy install that the guy cut them in half? Why?
Yes you have to cut the bumpstops in 1/2. You are lowering your car. Less shock travel. Cutting the bumpstop in half gives you more shock travel.
Where are the pictures we have been requesting?
Old Nov 23, 2009 | 06:44 PM
  #27
hialeahzbg's Avatar
ive been really busy at home....i might put the bumpstops on tomm...
Old Dec 7, 2009 | 06:05 AM
  #28
hialeahzbg's Avatar
Originally Posted by GroundControlTrevor
My appoligies, you must have used a different e-mail for the order. Anyhow, blaze the chemi is correct, the sleeves I sent you should be sitting on top of the circlip of the koni. There should not be anything between the sleeve and the clip.
If you can, get those spring rates off the springs and we'll see what we can come up with.
sent you a picture of the spring trevor...thanks!
Old Dec 8, 2009 | 05:14 AM
  #29
zserious's Avatar
Yea you deff do or else your gonna go threw your strut tower.
Old Dec 8, 2009 | 05:25 AM
  #30
hialeahzbg's Avatar
i put the bumpstops this weekend and it rides better than before...bumpstop deff helped out a whole lot...
Old Dec 8, 2009 | 07:13 AM
  #31
omnirage's Avatar
The bumpstop just stops the shaft from slamming all the way into the shock when you hit a pothole, it can also be used as sort of a helper spring to control travel. What most people describe as "bottoming out" is actually the upper A arm hitting the frame on the shock mount area.
Bumpstops also have the side-effect of reducing available shock travel, as it's protecting the shock from completely compressing. That's one reason why some choose to cut them in half. I choose to ride without them, instead opting for extended top hats. Bumstops would be sort of counterproductive in my opinion.
If you're going to ride around with your wheel/fender gap at or around 1 finger, you'll need suitable spring rates. Nothing less than 400 lb/in will do, or you will clunk every once in a while on rough roads, potholes, train tracks, etc.
Old Dec 8, 2009 | 08:02 AM
  #32
hialeahzbg's Avatar
well the rears are 200 according to GC its 200 in the rears..i forgot front and rears were different so i didnt check but i will try today...
milruner
Suspension & Brakes
Mar 15, 2005 11:04 AM
plamauski
Dec 21, 2004 06:24 AM
maggsgsr
Apr 1, 2003 04:14 PM
Shoe
May 22, 2002 06:07 AM
myst179
Apr 16, 2002 07:09 PM
