Suspension & Brakes Theory, alignment, spring rates....
eg toe in problem?
Old Mar 7, 2006 | 05:11 PM
4drcvc92's Avatar
Default eg toe in problem?
I have a crazy toe in problem on my 92 eg.
I have strut tower bar and was wondering if that could cause some the problem?
I also have old worn springs and struts but, would that cause this bad of a toe in?
I replace my front tires every month. I also replaced almost every part in the front end. outer tie rods, cv axles, hubs, lower control arm outer bushings and, upper control arm ( passenger ). Have added front strut tower brace and rear lower tie bar. Also the power steering unit has been taken out and the rack has been filled with fluid.
CAN ANYONE HELP?
Old Mar 7, 2006 | 05:15 PM
Tyson's Avatar
Default Re: eg toe in problem? (4drcvc92)
you ever get an alignment dude?
no a strut bar has absolutely nothing to do with steering.
Old Mar 7, 2006 | 05:18 PM
4drcvc92's Avatar
Default Re: eg toe in problem? (Tyson)
yeah, and it helped for about a week.
Old Mar 7, 2006 | 05:29 PM
Tyson's Avatar
other than your inner or outer tie rods being totally bad, theres no reason why your alignment should be out of alignment after a week of getting it aligned. are you hitting lots of pot holes???
Old Mar 7, 2006 | 05:31 PM
4drcvc92's Avatar
No pot holes.
But I replaced the tie rods myself do you think I should have twisted it onto the inner rod more than I did to pull the toe in?
Old Mar 7, 2006 | 05:32 PM
Tyson's Avatar
did you get an alignment AFTER you replaced the tie rod?
Old Mar 7, 2006 | 05:34 PM
4drcvc92's Avatar
Yup. for real, I have been racking my brain goin' crazy trying to fix this it is driving me CRAZY!!!!!!!!
Old Mar 7, 2006 | 05:36 PM
Tyson's Avatar
go back to the alignment shop and tell them to do it over again.
Old Mar 7, 2006 | 05:40 PM
4drcvc92's Avatar
Have you had this problem?
I really appreciate your help brotha.
Alcatrax30
Sep 3, 2014 04:35 AM
SharkEg
Suspension & Brakes
Jun 17, 2012 05:01 PM
CRX 2.0V-T
Jan 7, 2007 07:40 PM
JustinHoMi
Suspension & Brakes
Mar 9, 2006 09:35 AM
honda_coupe
Oct 24, 2005 07:25 PM
