Suspension & Brakes Theory, alignment, spring rates....
DIY-Alignment
Old Jan 14, 2009 | 10:09 AM
T3KNiQe's Avatar
Default DIY-Alignment
I give mad kudos to the man who made these videos...
http://www.youtube.com/watch?v=sZoL1...eature=related
http://www.youtube.com/watch?v=gjcP0...eature=related
http://www.youtube.com/watch?v=RpEwS...eature=related
Old Jan 14, 2009 | 10:16 AM
Barney Stinson's Avatar
Banned
Default Re: DIY-Alignment
yeh i get this done like every two years, i'll just pay the 60bux.
Old Jan 14, 2009 | 10:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Subscribing to watch later.
Old Jan 15, 2009 | 01:01 AM
92civiceg9gsr's Avatar
I give him props for doing all that work. I have a caster/camber gauge though.
Old Jan 15, 2009 | 02:18 AM
TotalBalance's Avatar
i am doing the same thing for the toe measurement at home.
havn't done any camber adjustment since i have no camber kits but it was good to know! great info!
Old Jan 15, 2009 | 05:07 AM
Community Builder
He said in the video that his method for checking toe will not work if your track width is not the same in the front and the rear. Well almost all FWD Hondas have a narrower track in the rear than in the front. The S2000 has nearly a 1.5" wider rear track than the front.
So you COULD use that method for checking toe, if your car is square, but you would have to do additional calculations to set up the string correctly. You would have to take the difference in track width, divide that by 2, and add that to your measurement from wheel center to the string at the axle with the narrower track.
Or if you could somehow find the exact centerline of your car, you could just measure off of that.
Old Jan 15, 2009 | 12:16 PM
beanbag's Avatar
His technique for finding the level ground using water is pretty neat.
Old Jan 15, 2009 | 12:56 PM
Tyson's Avatar
longacre toe plates and craftsman digital level with laser pointer is all you need.
you can align the front and rear thrust with this too. doesnt matter if the front or rear track is different width. as long as the car is square (no frame damage, or pushed in suspension). put a measureing stick to the front hub, point the laser level from the rear wheel and measure how far it is pointed from the front hub. compare both sides and it should be equal.
measure total toe with the longacre toe plates. and take it for a test drive.
camber is measured with the digital level too.
Old Jan 15, 2009 | 02:54 PM
Community Builder
The leveling technique is worth those videos IMHO if nothing else, since you need the car to be level in order to get accurate readings.
Old Jan 15, 2009 | 02:56 PM
Tyson's Avatar
i havent had time to sit and watch those vids in entirety, but with a laser level, how hard is it to figure out? you can get them for $30 at sears.
Old Jan 15, 2009 | 04:58 PM
EJ8chu's Avatar
I'll stick to my hunter lazer alignment rack
Old Jan 15, 2009 | 06:45 PM
nonsense's Avatar
Do you tow it to the track with you?
Old Jan 15, 2009 | 07:13 PM
carlitosway12345678's Avatar
sure. But a laser level and a measuring stick is a lot simpler...
Old Jan 15, 2009 | 07:48 PM
beanbag's Avatar
and less accurate...
Old Feb 25, 2010 | 09:51 PM
raidacaipo's Avatar
his method of finding the toe isn't accurate. You need to find the center line of your vehicle in order to measure the toe angles accurately. Measuring the center wheel hubs wont work.
9tailsfox
Jan 6, 2012 04:46 AM
Valvola
Sep 10, 2005 08:45 AM
mingbling96
May 10, 2005 10:52 AM
elpiar
Suspension & Brakes
Apr 30, 2005 10:41 AM
91_hatch_si
Dec 30, 2002 09:15 PM
