Coilover Install Experience
I woke up yesterday at about 7 in the morning. Dazed and untrusting of my car, thinking clearly of the small road trip ahead of me. I was going to have to go through the canyons again. It was scary last time the excessive roll of the body even at speed limit and under speed limit.
So I caved and pulled my coilovers out the box, looked up a quick DIY. And off to work I went. Equipped with a jack, jack stands and hand tools I went to work.
The old suspensions removed fairly easily. I took the old suspension and did some measuring. From the top hat to where the lower body met the fork. Designated a 1" drop from that point and moved on to the other side. With the front finished a quick test drive and settle. Pulled back into the drive tightened up the bolts. The rears were simple and after finishing install a quick bounce and test drive settle was in order. Pulled in and torqued it all down. It's hard to reach under the car and tighten those lca bolts.
The car was signicantly better though the height was not changed drastically it was well balanced in the corners.
So off to the canyon. I went with cautiously optimistic. Sweeping through the turns was nice and could definitely feel the difference. What had got to me was that some turns I would start to roll ever so slightly. My first thought was to slow down let the car bite in a bit. But instinct told me press the gas the car flattened out and railed the turn even more so.
So my cousin hopped in he knew the canyons far better than myself I thought I was going fast nope and the oh **** bar was getting grabbed at constantly until I realized we just took that 35 mph turn at 80 with out breaking a sweat.
So that's it for now guys. Oh and this was all done in a 1995 Honda civic CX stock 70hp. With 15x6.5 rims and kumho ecsta tires.
If you have any questions about the install please ask.
Thanks
Thanks
Yah I had figured as much, but with it being my first ever coilover experience it's hard to believe that it's such a difference. I'm thinking I should get my camber kits on and take it to get dialed in with an alignment and possible corner balance.
As far as sway bars I think I will hold off until I understand the car in its current position.
So down the line is swaybars, traction bars, all new bushings.
In laymans terms when dealing with swaybars and springs, bigger in the back=oversteer. Bigger in the front=understeer. This is an oversimplified explanation.
I'm looking forward to owning a similar setup.
My good friend and autocross confidant has the AMR 550/650 setup and it handles like a dream. Smoother on the road than my Progress CS-II 350/350 setup.
AMR is hands down the best suspension short of the $3,000+ setups out there.
And yes, the oversteer is a result of the rear bias rates. If you want some neutrality add a beefier front swaybar.
The rear of the car is about 3/4" higher than the font right now so going to aim to even that out soon.
Now I had a question my front now sits only at about three finger gaps. In long sweeping turns I feel the roll increasing unless I begin to accelerate and it smooths out push to hard I feel the push again.
Will swaybars help to alleviate that situation?
Maybe I missed it, but I didn't see "get the car aligned" anywhere in there. Was that even done after installing the suspension? If not, don't bother trying to diagnose anything about the handling until you do.
Great point perhaps I should hop on the bushings and make an appointment and have it all installed and done sooner rather than later.
With 550F rates you may not need a front bar at all. You can buy an adjustable swaybar for the rear, too.
*AMR Engineering Front UCA's
*King Motorsports Rear Camber Kit
Hardrace Bushings
New Lower Ball Joints( wish they made like 1/4" extended)
Full-Race Traction Bars
F7 Rear Subframe Brace
Wonder what else. Simple being best.
Thanks for all the insight guys.
*In Possession
But just because the coilovers have helped to increase cornering speed does not mean its increased my confidence in my driving ability. For now I remain modest.
I'd put the S. Drives on anything I didn't plan on pushing to the limits but wanted a quiet/safe summer tire with good road manners. I autocrossed a season on S. Drives and they were great, not nearly as good as my KDWs though. Totally different animal.
Star specs or RE-11's would be my recommendation. I wish star specs were made in a 205/45/16
Star specs are amazing. I enjoyed my Yokohama S. Drives.
