Suspension & Brakes Theory, alignment, spring rates....
camber problem
Old Jul 19, 2009 | 12:36 PM
beana's Avatar
Default camber problem
i have a problem with rear camber(negative), i was looking at it earlier today, i know my traling arm bushings are shot, the arm that connects the trailing arm to the chassis still has good bushings
could the trailing arm bushing cause my camber problem?
Old Jul 19, 2009 | 03:49 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: camber problem
what type of car you drive?? not all rear susp on hondas/acuras are the same.
Old Jul 19, 2009 | 07:13 PM
beana's Avatar
91 hatch
Old Jul 20, 2009 | 03:38 AM
Egezzy's Avatar
well your very first post is misleading so ill just run down all the "arms". first your trailing arm runs from the body back. at the front of the trailing arm is your toe adjusters. next arm back towards the middle of the trailing arm is your camber arms. then the lcas are at the back and run from the subframe over.
lorenzookc
Suspension & Brakes
Mar 14, 2010 04:47 PM
beana
Jan 4, 2010 02:08 PM
alex_s817
Jun 8, 2006 07:39 PM
func-tion
Jan 22, 2004 07:01 AM
