Suspension & Brakes Theory, alignment, spring rates....
Camber Kit Problem
Old Aug 27, 2007 | 04:13 PM
bballchris24's Avatar
Default Camber Kit Problem
so i have a problem with my skunk 2 camber kit on one of my tires. The bolts have come lose and now theres only 2 left which is causing my tire seem that it is about to fall off! (second time this happens)... does this mean i need a new camber kit or how could i fix this?
Old Aug 27, 2007 | 04:16 PM
PIC Performance's Avatar
Default Re: Camber Kit Problem (bballchris24)
get two more of those bolts to replace the lost ones, it's easy! While you're at it, put some big beefy washers in there to increase the contact area and prevent any possible slippage in the future. And get an alignment.
Old Aug 27, 2007 | 04:20 PM
i did that and it got aligned but they came lose again?
Old Aug 27, 2007 | 05:13 PM
Default Re: Camber Kit Problem (PIC Performance)
they are coming loose and falling out? That shouldn't be happening. Who is doing your alignment? Are you tightening those bolts down enough? The bigger washers will help keep them from slipping and loosening.
Old Aug 27, 2007 | 06:36 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bballchris24 &raquo;</TD></TR><TR><TD CLASS="quote">so i have a problem with my skunk 2 camber kit on one of my tires. The bolts have come lose and now theres only 2 left which is causing my tire seem that it is about to fall off! (second time this happens)... does this mean i need a new camber kit or how could i fix this?
Does Skunk2 provide a recommended torque for those bolts? Sounds like they aren't being tightened enough. Though I have heard a few people claim that it takes washers, and the removal of the powder coating on the arms, to keep those bolts in place.
Never had an issue with my SPC UCAs slipping or otherwise loosening, though I do insist the alignment tech torques the single nut down to the recommended 120 ft-lbs...
Old Nov 4, 2007 | 03:46 PM
jasonjai's Avatar
Default Re: Camber Kit Problem (TunerN00b)
try this:
put some "permatx loc-tite thread sealer" on your replacement bolts, you should be able to get this at an auto parts store for about $7 or less. they have different versions of this too, the blue version should be good enough.
*remember to get the correct torque specs, and torque them up.
hope this helps!
bikerbo1
Apr 16, 2008 11:42 AM
kasperxtcy
Suspension & Brakes
Mar 26, 2008 01:59 PM
bballchris24
Aug 27, 2007 03:48 PM
unknownracing
10
Jul 7, 2007 08:18 PM
iLOVEthatEMone
Suspension & Brakes
Jun 25, 2007 11:55 AM
