Suspension & Brakes Theory, alignment, spring rates....
brake bleeding
Old Mar 26, 2013 | 05:01 PM
padre2/3/11's Avatar
Default brake bleeding
ok so I have a 94 integra gsr I did a brake tuck used the rywire brake tuck kit 40/40 prop valve rs master cylinder and booster but cannot get the passenger brakes to get pressure any help would be realty appreciated
Old Mar 26, 2013 | 05:06 PM
Default Re: brake bleeding
its like only one line on the mc is getting brake fluid its a new mc tho
Old Mar 26, 2013 | 05:07 PM
Fliptard's Avatar
did you make sure everything is hooked up where its suppose to be? make sure nothing is leaking? are you using the OEM rubber lines to the caliper? if so, might have colapsed
Old Mar 26, 2013 | 05:14 PM
have checked for leaks no leaks double checked all lines on the prop valve over and over again and yes using the oem soft lines to the caliper but when I crack the front line of the mc there is no fluid there.....the mc was bench bled I am out of ideas
Old Mar 31, 2013 | 02:10 PM
NVturbo's Avatar
O.G. triple O.G.
This may be farfetched. ...but is there any plug caps blocking the calipers or brake lines?
brokebuilder
Jul 6, 2017 08:52 AM
93962
Honda CR-V & Element
May 13, 2017 05:41 PM
hteg12
Jul 18, 2013 05:13 PM
slowesteg
Sep 4, 2012 07:59 PM
92integraVTECgsr
Nov 7, 2005 09:15 PM
