Tipe R Pistons in ls?
Old Sep 22, 2004 | 04:50 PM
Edsan's Avatar
Default Tipe R Pistons in ls?
I recently got a new b18b block for my stcok ls. But the block comes with P73-AO (which are for USDM Type R, or thats what i´ve been told) instead of the PR-4 that would be ls stock ones.
Then my comp should go from 9.2 to 10.3. I know that much, but Is there anything that I should modify or take particular care of. Do I really need to do a tune for such a small difference and what do I have to do?
Thanx all for your help, the engine is being installed right now so I will really appreciate your comments.
Old Sep 22, 2004 | 05:41 PM
patmcd's Avatar
Default Re: Tipe R Pistons in ls? (Edsan)
Yes you should have it tuned. Thats a good jump in compression. Also personally I would no longer use 87 octane either.
Old Sep 22, 2004 | 07:11 PM
boosted k20's Avatar
Default Re: Tipe R Pistons in ls? (patmcd)
true, u need to use 91 or higher octane with those pistons
Old Sep 23, 2004 | 06:54 AM
Edsan's Avatar
Default Re: Tipe R Pistons in ls? (boosted k20)
Morning Bump!
Old Sep 23, 2004 | 09:25 AM
Sack Master's Avatar
Probably want a little more cam and fuel in there as well. Also open your spark plugs up a bit.
Old Sep 23, 2004 | 03:51 PM
Edsan's Avatar
Default Re: Tipe R Pistons in ls? (Sack Master)
It would be nice if someone could tell me exactlly what I need to do to the car, Ì'm totally ignorant about mechanics so It would ba great help. That way I can make sure that the mechanic actually does everything he needs to,
Thanx.
lluks_844
Northeast (Sales)
Sep 17, 2009 10:15 AM
splickitysplat
Oct 1, 2007 03:01 PM
jdmefhondachassis
Aug 17, 2004 10:50 AM
92B18Bvx
Mar 12, 2004 11:36 PM
