Will a ngk copper plug for a ls work in da R
Old Sep 22, 2004 | 03:50 PM
mikestypeRR's Avatar
Default Will a ngk copper plug for a ls work in da R
I know this has been posted alot but i cant find the original post about it...
I have a set of ngk v-power plugs for the ls .. they have a heat range of 5 ...
I know alot of you guys use the ls plugs... but all i can find them in is a heat range of 5, cant find heat range 6....
so the question is does the heat range really matter?
and will the ls plug work the same as the factory R plug?
if not i will just say **** it and buy the factory one. thanks for your help
Old Sep 22, 2004 | 04:13 PM
[HrZn]4life's Avatar
Default Re: Will a ngk copper plug for a ls work in da R (mikestypeRR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikestypeRR &raquo;</TD></TR><TR><TD CLASS="quote">I know this has been posted alot but i cant find the original post about it...
if not i will just say **** it and buy the factory one. thanks for your help</TD></TR></TABLE>
I don't know for sure but I don't think there would be an issue; also, the zfr6f-11 shouldn't be that much harder to find than the 5f. Local autoparts stores usually carry both...at least the ones I live around. Good luck.
Old Sep 22, 2004 | 05:26 PM
Default Re: Will a ngk copper plug for a ls work in da R ([HrZn]4life)
anyone else?
Old Sep 22, 2004 | 05:29 PM
Opie's Avatar
Did you get the caR yet? Where are the pics bitch?
DC4R27
Apr 16, 2007 03:53 PM
SiR Inspired ED7
Oct 4, 2005 05:44 AM
bOOsTiNSoHcVtEc
Aug 4, 2005 08:15 AM
davejj40
Aug 29, 2004 10:03 PM
chahsiubow
Jun 23, 2004 09:29 PM
