B18a1 swap in a 90si hb
Old Sep 22, 2004 | 03:38 PM
SI HB's Avatar
Default B18a1 swap in a 90si hb
How do i go about putting this motor in and is it worth it..Will i lose the vtech should i just grab a b16 this is my first time moving into the killer bees so can somebody help me out in a big way.. Im just new guy lost in the sauce need HELP please A step by step or something
Old Sep 22, 2004 | 04:07 PM
mntuner2's Avatar
Default Re: B18a1 swap in a 90si hb (SEDAN PUSHER)
1. No replacement for displacement. (CRVTEC anyone?)
2. The B16a/b's , B18c's head flows a lot better than anything else.
3. Go buy the new sport compact car for a detailed guide on how to convert your crappy b18a or b18b into a VTEC snortin' pimp motor.
4. You'll need a Hasport EF motor/tranny mount kit plus the shift linkages. Rear mount, axles and hubs can be purchased at the junkyard from a 90-93 db or da Integra I think others too. You get good brakes from the Integra.
5. Your gonna have to convert to multiport fuel injection. If allready great wire up the vtec and find an obdo VTEC computer or a aftermarket one. Do a search on google for "DPFi to MPFI" and i'm sure youll find somethin golden. I think someone by the name of chaco has a good guide.
6. Keep the clutch non-hydraulic cause it will make the conversion alot easier.
Ummm.....
Old Sep 22, 2004 | 04:23 PM
SI HB's Avatar
ok sounds like touch much work in the little time i have so thats out the window looking for a easier swap then that. so the b16 would work a little bit better ? thanks for the info anybody want to buy a b18a1
Old Sep 22, 2004 | 04:28 PM
Sick79's Avatar
b18 should be a little simpler to do because theres no vtec to wire up.
and you dont have to do the mpfi swap because you have an si. if you already have the b18 i would put that in.
Old Sep 22, 2004 | 04:47 PM
SI HB's Avatar
ok ok look i have a 90 si hb d1.6 now high high miles i also have that b18a1 full motor no tran 80,00 miles and a fully rebuilt d15b port polish,rings ect unused i know its not the best stuff but any ideals out there besides throwing out ..
Old Sep 25, 2004 | 04:59 PM
mntuner2's Avatar
Default Re: (SEDAN PUSHER)
You can ship it to me? How much to Richfield, MN 55423
Old Sep 25, 2004 | 06:45 PM
CRX_1.8T's Avatar
Default Re: B18a1 swap in a 90si hb (mntuner2)
shortened 90-93 shift linkage will work. shorten it 2 3/8 inches then weld.
Old Sep 25, 2004 | 07:20 PM
Steemo's Avatar
Default Re: B18a1 swap in a 90si hb (CRX_1.8T)
a b16 will be no easier then a b18 same amount of parts required except for the b16 you will have to wire up vtec. if you have a rebuilt d15 you could drop that in with out any new mounts or shift linkage. and you could use the tranny you have in there right now. its all up to you. just search this site and all your questions will be answered. b series swaps have been covered big time. check this site for more info. http://www.geocities.com/speed...p.htm
thats pretty much everything you need to know. read up. take your time. do it right
Old Sep 25, 2004 | 10:38 PM
EVOLUTIONINNYC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEDAN PUSHER &raquo;</TD></TR><TR><TD CLASS="quote">Will i lose the vtech should </TD></TR></TABLE>
if you cant spell VTEC right, and dont know the LS is nonVTEC, you shouldnt be doing this swap yourself
Old Oct 2, 2004 | 11:45 AM
mntuner2's Avatar
Dude are you gonna sell it or not?
Old Nov 28, 2004 | 01:22 PM
SI HB's Avatar
Default Re: (Sick79)
It's been a while but thanks for the reply I needed that and if you still want that motor lets talk
SirDreadsALot
Jan 6, 2011 09:09 PM
EFlove91
19
Oct 28, 2009 07:36 AM
hyrev20
Nov 3, 2008 07:13 AM
quintanaporvida
Jul 27, 2005 12:42 AM
shorty-j
May 14, 2003 02:58 PM
