very quick questions
what kind of lube is used for a pilot bearing and other bearings on the trans...also after removing the trans housing do you need hondabond or some type of sealant when you put it back on?
TIA
TIA
usually when i do a clutch, i spray it down with brake cleaner getting rid of all the dust and debris. then let the sun dry it completely. i use white lithium grease on the bearings. works like a charm
mgags7
Sep 28, 2005 06:31 AM
