JDM SiR Cluster:little door open indicator wiring. if u have one please read
ok installed my JDM Sir Cluster today, but i have a question.
i can't seem to get the door or trunk open lights to come on.... (but i think i might have my own answer). I did not hook up D1 White/blue (illuminates all doors when ground (-) is applied) from small green plug on back of cluster, my question is does this have to be hooked up for a ground source for the display, since d10 (black/yellow) is said to be switched power.
http://students.washington.edu....html no longer works this is where i got the info to install my cluster.
Modified by Majin Vegita at 11:57 PM 9/26/2004
i ran my vss signal wire directly to the ecu, then spliced that to the cluster
i did it the oposite, works fine, guess either way you want to do it is fine... sweet. now what about that little door open diagram.....
SedanMan206
Sep 12, 2012 06:28 AM
SFWDcoupe
Jun 22, 2006 10:39 AM
civic-tantrum
Jul 3, 2004 01:43 PM
