h23 v-tec???
Old Sep 22, 2004 | 08:55 AM
scratchy's Avatar
Default h23 v-tec???
searched the archive and came up with some info but want to swap the h23 v-tec from the accord wagon and i wanted to know if anybody has come out with the mounts or if it has to be custom done, and i was told there is a converter plate to swap the b tranny on the h-motor???
Old Sep 23, 2004 | 05:03 AM
scratchy's Avatar
Default Re: h23 v-tec??? (scratchy)
bump
Old Sep 23, 2004 | 07:04 AM
EL Vap133's Avatar
1. It's "VTEC" not "v-tec".
2. The H23 is a non-VTEC motor.
Old Sep 23, 2004 | 07:09 AM
4drEF's Avatar
Keyboard Humorist
Default Re: h23 v-tec??? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">1. It's "VTEC" not "v-tec".
2. The H23 is a non-VTEC motor. </TD></TR></TABLE>
Old Sep 28, 2004 | 06:40 AM
scratchy's Avatar
i call bullshit on the h-23 not being vtec dumbass
http://www.jdmsource.ca/honda/h23a.html
i have done some research and i have found it so before you go and start talking **** i might know a little, i'm not your run of the mill ricer
Old Sep 28, 2004 | 06:48 AM
eumoria's Avatar
The H23 engine comes from the EuroR Accord and it is non-vtec. It's also not rated at 200HP... it's higher.
It is possible to do the H-Series "LS/VTEC" and put an H22 vtec head onto an H23 block. That site is obviously selling a modified engine. If you want more info on this you're better off talking to the Prelude or Accord guys.
No need to "call bullshit." H-Series aren't discussed regularly here. Try over with the 'lude or accords.
H-Series is a very difficult swap in an EF, so doing a bigger block with a modified head into a car that's not even close to being made to accept it is quite a challenge. I'd say good luck, but I think you may wanna try a big B-Series.
*EDIT: After searching I see conflicts on Preludes and Accords whether or not is was VTEC. I still believe it's a non-vtec motor but maybe some JDM Preludes came with a VTEC model. Now I'm confused.
Old Sep 28, 2004 | 08:05 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scratchy &raquo;</TD></TR><TR><TD CLASS="quote">i call bullshit on the h-23 not being vtec dumbass
i have done some research and i have found it so before you go and start talking **** i might know a little, i'm not your run of the mill ricer</TD></TR></TABLE>
Who do you think you are fucktard?
sothasom9
Oct 10, 2007 10:06 AM
ludelover04
Jun 8, 2004 06:57 PM
rkonfire
May 18, 2004 09:33 AM
