my car squeaks with every little bump
Old Sep 22, 2004 | 07:27 AM
ityab0y's Avatar
Default my car squeaks with every little bump
Hey, thanks for reading. Every time i hit the slightest bump in the road, or even the little tiny rivets in the parking garage, my car squeaks like crazy, even when i'm just parked somewhere and the bass hits, it makes the car squeak. Also when i close my door it squeaks, it started 2 weeks ago and has been getting worse since. It sounds like a hamster running real fast in their little excersize wheels. It seems like its coming from under the hood, by the drivers side fender. I popped the hood to check it out, but when the hood is popped, the noise stops, i guess it could be somehting with the hook latch but everything seems fine. I have no idea where it is coming from.
Thanks for any advice you have to offer.
Old Sep 22, 2004 | 07:29 AM
handa's Avatar
Default Re: my car squeaks with every little bump (d0nfry)
sounds like it could be the belt. but after opening the hood and it stops...that's another story.
Old Sep 22, 2004 | 07:31 AM
ej0513's Avatar
could be your bumper.. or suspension.. both of mine squeak.. on the bumper it could be the little white things on the quarter panels that the screw goes it vibrating.. move your bumper up and down on the sides carefully and listen.. that may be the problem.. have you done anything to your car as far as mods go? suspension mostly..
Modified by ej0513 at 11:48 AM 9/22/2004
Old Sep 22, 2004 | 07:32 AM
usdm_dc2's Avatar
Default Re: my car squeaks with every little bump (handa)
my car does the same thing. i work at an acura dealership and i asked them about it and they said that it is probably bushings that had gone bad in my suspension
X01Michael
Nov 9, 2010 08:41 AM
Honda-bond
Jan 11, 2010 09:23 PM
Bedgoodmrb
Dec 20, 2009 09:40 PM
xo0hamsta0ox
May 23, 2007 06:11 PM
vxnine
16
Oct 20, 2004 04:07 PM
